Old 06-17-2023, 09:01 PM
Twthompson Twthompson is offline
Default Make Drive Shaft Flex Coupling
Has anyone made drive shaft flex couplings? If so where did you get the material? New ones are about $21 each and up. It sure look like with a jig saw and a drill they would be easy enough to make. Thanks for any suggestions.
Old 06-17-2023, 11:06 PM
The flex disc joints could be made using an old tractor/big truck tire.
But why? the original ones last 30-40 years.
So if you replace them with factory new, they prolly will be good when you are gone or no longer have the tractor.
Just my thought.
Old 06-18-2023, 07:43 AM
These need to be precision cut/punched to maintain balance.
Old 06-18-2023, 08:24 AM
CubDieselFan's Avatar
Something to keep in mind, the new ones are a different thickness so you will need to plan for that.
https://www.onlycubcadets.net/forum/...ad.php?t=60262
Old 06-18-2023, 08:27 AM
Old 06-18-2023, 10:20 AM
Depending on which model machine you have Mr. Charlie has them for $17 each.
https://ccspecialties.org/flex.html
Old 06-18-2023, 01:23 PM
Thanks. I had not seen these.
