Old 07-01-2023, 10:05 AM
zer0vector zer0vector is offline
Default Is this the right carb and air cleaner?
I've got a weird issue with this Cub Cadet 1000 with a K241 motor:
https://imgur.com/a/STFAsMA
When the air cleaner housing is installed on the carb, it hits the choke linkage quite a bit (so much that the linkage has worn the paint off the back of the housing). The indent on the air cleaner housing is so deep it goes back pretty far. It seems like I'm either missing some sort of spacer or the carb should be ~3/4" longer.
This is *clearly* some sort of replacement carb, not original, so I suspect that is the problem, but open to any other ideas. It certainly looks like a lot of the pictures I've seen of stock carbs so nothing obvious is jumping out as the issue.
Old 07-02-2023, 12:47 PM
greg r greg r is offline
The choke toggle, the link attached to the fan housing, is bent outward. It needs to be straight, maybe even a tad inward. The carburetor looks correct.
Old 07-05-2023, 11:53 AM
Yep, I think that was it. Took a side look at the two choke linkages and they're both bowed out pretty far. I'll straighten them up and hopefully not get any snags. Thanks.
Old 07-09-2023, 09:30 AM
dale c. dale c. is offline
the choke lever on the quiet line tractors point back towards the engine not out towards the air cleaner .
