Old 07-26-2023, 03:56 PM
Graflex45's Avatar
Graflex45 Graflex45 is offline
The dividers underneath are still in place and in good shape
the only thing missing from it is the downward diverter piece on the output chute, need to get around to making on out of some scrap metal
Old 07-31-2023, 09:37 AM
garydee's Avatar
garydee garydee is offline
Default Deck Blades
The first thing that comes to mind is that the blades are not the correct length for the 44a deck. The blades should nearly touch one another with a slight gap between them to cut correctly.
More often than not, this problem occurs with aftermarket blades that are generic, to fit a variety of mowers. Check the gap between the blades to be sure the blades you have are indeed the correct set. I believe the blades for the 44a deck are 15.12 (15 1/8) inches long.
To be sure, research the Cub Cadet model number for your deck with the correct vintage to determine the blade set you should be using.
Old 08-04-2023, 04:50 PM
ChristopherCT ChristopherCT is offline
Default new blades, nice cut
An update- I purchased the inexpensive blade set mentioned by SamMac They are XHT brand. Black, basically rectangular and thicker than my originals.
The cutting quality of the deck has improved GREATLY.
I am guessing that my annual sharpening was helpful, but the loss in blade width, or my rounded blade corners were causing poor performance. The deck also seems to blow harder on exit now. Thanks everyone for your input
Tags
44a mowing deck, blades
