Old 10-17-2023, 10:37 PM
quadracerx quadracerx is offline
Default 149 Governor Question
So I finally got the 149 to run... The new Amazon Carb works.. Now I have to figure out Throttle and Choke Cables... But...
My biggest question at the moment is in regard to the Governor Arm.. I cant reuse the factory on its frozen solid... Ive tried Croil, PB Blaster and Ultrasonic Cleaner.... So... The new carb came with a new governor arm... It was to long so I cut it shorter... Now with the new arm there is no play in the governor arm.... IS there supposed to be a small amount?
Thank you
Old 10-18-2023, 02:40 PM
How about a pic of what your dealing with and are you calling the throttle arm a governor arm?
Old 10-19-2023, 05:44 PM
Based I your photo... The part I was calling the Governor Arm was incorrect. The rod I am speaking of connects the Governor Arm in the photo to the Throttle on the Carburetor... Sorry
Also is there supposed to be a bit of play on the Governor Arm connection to the throttle on the carb?
Thanks for your help
Old 10-19-2023, 08:51 PM
Does it run fine? When a load is applied the arm will move. Also be sure to check the max rpm, 3600 rpm. There is good info in the service manual located here...
https://www.onlycubcadets.net/forum/...ead.php?t=4647
Old 10-19-2023, 09:22 PM
There is a spec for the length of that arm in the service manual from the center of the ball to the center of the rod at the bend, adjustable so that when the carb is at WOT the governor should be properly adjusted per the instructions in the manual.
Old 10-25-2023, 11:53 PM
I think the AMAZON Carb the choke is a "push to close Choke' not like the factory "Pull to Close Choke" is there an easy way to fix this?
Old 10-26-2023, 09:23 AM
Yes, obtain the correct carb or rebuild the one that was originally on the tractor.
It should be a Carter #30
Old 11-20-2023, 05:31 PM
Ok... Still figuring out the Throttle and Choke Cables. I have the Choke figured out I think.... Im replacing the entire cable and housing.
For the throttle, I just need to replace the cable, want to try and keep the original housing. But I cant find a photo of the Throttle Lever from the side where the inner cable connects with the Z Bend. Anyone got such a photo?
Im hoping I can just slide a new cable in the housing and put a Z Bend on the Throttle Lever end without removing the Throttle Lever itself from the dash?
Thanks again for all the help... Getting closer!!
