Old 12-14-2023, 09:30 AM
zilla24's Avatar
zilla24 zilla24 is offline
Default Paint Mix Ratios
In the next week or so I hope to spray my 1572 fenders and body panels. I have some experience painting but am by no means a professional, I will be using a HVLP gun with 1.3 or 1.4 tip at approximately 32psi.
The paint I purchased didn't have much for instructions on mix ratios, here are my plans below I'm hoping someone with experience using these paints can validate whether or not I am on track.
Cub Cadet yellow (759-3263)
Paint - 8
Reducer - 4
Hardner - 1
CNH Ironguard white (935)
Paint - 8
Reducer - 4
Hardner - 1
CC Tractors: 1650, 1200, 800, 149, 86, 782D, 2072
Gone but not forgotten: 1450, 1250, 1000, 125, 1572, 782D, Original
Old 12-15-2023, 06:57 PM
ccguy's Avatar
ccguy ccguy is offline
Your Paint/Reducer/Hardener ratio has always worked for me using a 1.3 nozzle.
For Majic Paint, my ratio is 8:4:1.5 It has a much longer dry time so I add extra hardener to counter that reality and it’s “softer” properties when cured. With the extra hardener, it dries rock hard and I have never had it chip. Their hardener has a very high gloss.
I have never had much success using Cub Cadet acrylic enamel because they don’t sell a reducer or hardener designed for the chemistry of their paint - requiring you to mix products from various manufacturers. I could never find products that mixed or sprayed well with it. Folks on various sites rave about NAPA products so you may want to start there for a compatible reducer and hardener.
CaseIH sells a great product but I was told (Messick’s) that they didn’t sell a hardener so I stayed with Majic with pretty good results. I understand if you leave your equipment outdoors however, Majic paint has a tendency to fade.
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
