Old 01-12-2024, 12:44 PM
starclassic starclassic is offline
Default 2084 threw a PTO belt and now it won't turn
First big snow in Chicagoland. I'm running a 551 45" snow thrower attachment off the front of my 2084. Snow's on the wetter side but worked fine all the way out to the front of the driveway when the PTO belt popped (snapped and frayed).
I got it shut off and the tractor back to the garage. Picked up a replacement belt at tractor supply, got the new belt back on, but now the PTO won't engage. It's got power, in that when I throw the PTO switch, I can see it try to engage, but it doesn't start spinning, it just clicks.
Is my clutch ruined? I've had this machine 2 years and the PTO has been totally fine throughout. I have no experience working with the PTO. Hoping someone has a recommendation?
Thanks in advance.
Old 01-12-2024, 07:07 PM
Does it work with the belt off? Otherwise the bearing may have seized, there are 2.
Up to 534 and counting...
Old 01-13-2024, 08:30 AM
You need to check the air gap as per the manual.
Look on page 19.
https://ia801906.us.archive.org/10/i...103/580103.pdf
This is from our tech section.
https://www.onlycubcadets.net/forum/showthread.php?t=30
Old 01-22-2024, 02:26 PM
Mcamp Mcamp is offline
you might have a piece of the old belt stuck in the pto keeping it from engaging
Old 01-22-2024, 07:02 PM
Check and see if you may have hit something and it'd now caught /jammed in the auger.
Does the auger want to turn by hand?
Old 01-22-2024, 07:26 PM
Check to see if when it tossed the belt did it rip the wire to the PTO off.
Old 01-25-2024, 12:18 PM
walkertxr walkertxr is offline
I just had a similar issue with my 2084 and 451 blower. Blower stopped turning and started burning the belt. Shut off and went to re-engage it would kill the motor right away. Took the belt off and blower turned ok, same with the pto. Turns out the idler pulley locked up the turns the belt 180. Installed a new one and back to work.
