Old 01-24-2024, 06:22 PM
dadej dadej is offline
Default 782 snow blower
What blower will mount on a 782? I have a older blower but the model number is unreadable.
Old 01-24-2024, 06:38 PM
This is the list of attachments from the Cub parts site that fit and are approved for the 782.
90-364-100 45" Snowthrower (IH Design)
190-364-100 45" Two Stage Front Mounting Kit
190-364-100 Two Stage 45" Blower Frame
220 32" Lawn Sweeper 190-220-100
222 38" Lawn Sweeper 190-222-100
335 46" Triple Rear Bagger 190-335-100
336 46" Mower Garden Tractor 190-336-100 GT
357 38" Mower 190-357-100
358 44C 44" Mower 190-358-100
359 50C 50" Mower Garden Tractor 190-359-100 GT
360 50" Mower Adapter 190-360-100
368 10 Cu. Ft. HD Utility Cart 190-368-100 190-368A100 190-368B100
375 42" Snowblade
376 54" Snowblade 190-376-100
377 Blade Mounting 190-377-100
378 Hydraulic Blade Angle Package 190-378-100
386 Sleeve Hitch Adapter 190-386-100
388 3 Point Hitch w/Spring Assist 190-388-100
38C Rotary Mower
400 8 HP Tiller 190-400-100
404 Adapter for 400 w/Sleeve Hitch 190-404-100
405 Adapter for 400 w/3 Point Hitch 190-405-100
425/425A 17 Cu. Ft. Utility Cart
428 Disconnect Clutch Kit
438 Broadcast Spreader
443 Front Weight Bracket Kit
447 Rear Weight Bracket Kit
450 45" Snow Thrower 190-450-100
521 Utility Cart
653/653A 10 Cu. Ft. Utility Cart
H42 Snowthrower Gearbox and Mounting
H42/H48 Snowthrower Electric Chute Control
Haben Snowthrower
Old 01-25-2024, 04:18 PM
Farmall450's Avatar
Of Sam Mac's list, I'd rec'd the #450 (I have had that on both my 1811/now 1862).
Old 01-25-2024, 05:38 PM
QA36B and QA42B also, you must have the curved lift straps to install.
Up to 534 and counting...
