Old 04-03-2024, 05:38 PM
zacsdad zacsdad is offline
Default Battery info.
Hi Folks. I need a battery for my Model 1863 Cub Cadet. What replacement is suitable ? Thans for any suggestions
Thank You all, for the great advice Now... if it only stops raining and finally dries out....
Old 04-03-2024, 10:32 PM
brudder brudder is offline
The original is a 26R. Not sure what else will fit.
Old 04-04-2024, 03:15 AM
Cannon51's Avatar
Cannon51 Cannon51 is offline
I use U1 lawn and garden batteries from Walmart in my 1641 and 1863. They might not work as well in the north but do alright in GA.
Cannon
Old 04-04-2024, 12:03 PM
garydee's Avatar
garydee garydee is offline
Default Battery
The 26R battery is the right size with the top terminals reversed for proper orientation (negative closest to firewall and terminals on the left side). You can get a 525 cca battery at Walmart or Runnings for about $80.
Car batteries make good replacements if the right size. If it poops out in a tractor, it’s not as much of a problem as with a car..
If you use a trickle charger when the tractor is not being used, your battery will last a long time. I had one last for nearly 20 years because I religiously looked after it.
Be sure to use a battery tray and secure the battery with the clamp on the bottom to avoid leakage. Use a maintenance free type battery.
Old 04-04-2024, 02:34 PM
Farmall450's Avatar
I got lucky and found a 26F used on marketplace in the town over. I think it was only $30-40 (a year or two old) and cranked over the CC just fine.
Old 04-04-2024, 05:50 PM
garydee's Avatar
Default Battery info…
Good deal! Anything that is a close fit will work just fine!
