Old 04-13-2024, 01:13 PM
three4rd three4rd is offline
Default Why did these older motors not have an oil filter?
Always wondered. Why a transmission but not an engine oil filter? Got me to thinking about it today while changing the oil. I've been changing the trans filter every year of late - probably wouldn't need to since the tractor runs way less than 50 hours a year.
Old 04-13-2024, 05:55 PM
spndncash spndncash is offline
I do not know the engine you are referring to but I assume it is one with no oil pump. No pump means no filter.
Old 04-13-2024, 07:35 PM
Ozcub's Avatar
Ozcub Ozcub is offline
My push mower has no filter , splash feed works pretty well so long as you do not mow at an acute angles and change the oil regularly using a good quality oil
B&S motor
Oz
Old 04-13-2024, 07:38 PM
My Cub Cadet 129 - Kohler 301 engine
Old 04-13-2024, 08:48 PM
A simple splash system, thus no pump no filter.
Old 04-14-2024, 08:58 AM
If you can find a K330 or K331, they have an oil pump, but alas no filter.
Up to 534 and counting...
Old 04-14-2024, 09:22 AM
It is probably overkill but on my K301s I change the oil a couple times
at least through the summer. Probably amounts to every 10-15 hours.
I figure it is a pretty cheap filter system. Just drain and fill.
Ken
Old 04-14-2024, 09:38 AM
Farmall450's Avatar
Same with some KT17 and maybe even M18 applications.
Old 04-14-2024, 01:03 PM
Thanks for the replies! Have a good Sunday everyone.
Old 04-22-2024, 11:58 AM
wconner0190 wconner0190 is offline
my 1225 from 1992 has no filter either.
