Go Back   Only Cub Cadets > Cub Cadets > Cub Cadet Rear Engine Rider & ZTR (RER)
Old 04-28-2024, 08:21 PM
Billy-O's Avatar
Billy-O Billy-O is offline
Originally Posted by Papamoo44 View Post
Correct, back tires are normal air tires, but the caster tires are solid. Is there any way to tell if the frame is bent? I bought it used obviously, but in pristine condition. Looked like it was hardly ever used. Had less than 50hrs on it.
What are the pressures in PSI of the back tires? They should be even.
Plow blade
#2 Cart
QA36 snowthower
Old 04-28-2024, 09:11 PM
garydee's Avatar
garydee garydee is offline
Default Something wrong??
That'good news! Is the bolt long enough to add a washer or two to adjust one of the front wheels so they both touch the ground?
