Old 04-29-2024, 01:11 PM
MitchJ MitchJ is offline
Default Front Axle fun!
I had the front axle on my 782 sandblasted, and I'm now checking it out, etc. I was trying to see if the grease fittings were still good. I tried pumping grease into them, but it was a no-go. But grease did come out on the ends. I did find out—I never knew—that those spacers are removable! I just assumed the bolt was the pivot point.
I assume I can just beat those old inserts out of the axle clean them up, and pop them back in?
Old 04-29-2024, 01:27 PM
Don't "beat " them out, you will mushroom the ends and ruin them.
You need to press them out if they are stuck
That "sleeve" is supposed to be locked to the knuckle by the 1/2" bolt w/castle nut when tightened and turn in the axle casting as an assembly when you steer.
You have some serious cleaning and polishing to do once they are removed
Old 04-29-2024, 04:01 PM
Default thanks
Thank you, that gives me a reason to get another tool! I need a press
