Old 05-02-2024, 11:58 AM
tewtoys tewtoys is offline
Default cc 169 lift bar
what is the length of lift bar for a 169 , center to center
i have one but not sure if it is correct
thanks
Old 05-02-2024, 12:22 PM
Needs to have abend in it, same as other wide frames
Post a picture of it
Old 05-04-2024, 06:06 PM
it does have a bend, still on tractor
just not moving as much as i thought it should
i will check a little more
but thanks for info
we got to keep this site going no matter what, ton of info from everyone
Old 05-07-2024, 01:13 PM
Farmall450's Avatar
but thanks for info
They don't move a ton. I think I have a WF one, I can try to measure it at some point.
Old 05-07-2024, 01:32 PM
ironman's Avatar
ironman ironman is offline
27 1/4" total length
25 1/2" holes center/center
Old 05-07-2024, 03:19 PM
3/4" holes, each end for a WF lift bar
Do you have the lift bar plate that bolts to the rock shaft?
Old 05-13-2024, 07:28 PM
thanks all for info
a super forum for cub cadets and a 74 yr old fan/collector
