Old 08-20-2024, 02:57 PM
149Chris 149Chris is offline
Default QL 1200 - Cracked Oil Pan - Replacement
Chased a nagging engine oil leak on Quietline 1200. Found a crack in the oil pan. Read on here somewhere previously about replacing aluminum pan with cast iron. Is there a model that had a cast iron pan or isn't that easy? K301AQS engine.
Old 08-20-2024, 10:34 PM
Cubcadet70100 Cubcadet70100 is offline
I've got cast oil pans for sale shoot me a message
Old 08-22-2024, 07:44 AM
jbrewer's Avatar
jbrewer jbrewer is offline
That pan looks like a candidate for some JB weld therapy.
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
It's only original ONCE!
Old 08-22-2024, 08:32 AM
As well as re-machining of the threaded bosses and replacement motor mounts which probably cause the issue in the first place
Old 08-22-2024, 09:01 AM
jbrewer's Avatar
Oh Mister Helicoil! I have a job for you....
61 and 63 Originals
123 (2)
782D
106,
147, 122
102
parts
Old 08-22-2024, 09:33 AM
Those bosses need to be the same height all around in relation to the mounting surface of the pan proper to the engine block.
Old 11-23-2024, 09:16 AM
Default Fixed it - Make sure bolts don't bottom out
I bought a cast iron oil pan off of ebay. The package included the oil pan to engine and the oil pan to tractor bolts. I noticed I used bolts for the oil pan to tractor that were slightly longer when I changed the mounts last year. They bottomed out when I torqued them tight but I am convinced this combination allowed the damage to happened. In my defense, not the easiest place to see. Parts breakdown shows 3/8x2-1/4" bolts. OOPS!
Old 11-23-2024, 09:44 AM
Ref:
158
N/A
Screw w/Lock Washer, 3/8-16 X 1-1/2 Znd Hex Hd | (Common Hardware, Purchase Locally)
Old 11-23-2024, 11:19 AM
Default Correction- 1-1/2" is right
The 2-1/4" are thru the rubber bushings, 1-1/2" into the oil pan. Saving the old pan for a template if I ever need to do another Quietline mount that needs the welded in brace as detailed elsewhere on the forum. Thanks
