Old 10-27-2024, 08:09 PM
Bronco2ww Bronco2ww is offline
Default 128 clutch release rod
Does anyone know if a clutch release rod off a narrow frame tractor the same as a wide frame? I ordered a new release lever but now I can’t find the rod for my 128. (It was missing a lot of parts )Or if someone knows the measurements of this part. Thanks
Old 10-28-2024, 07:13 AM
ironman's Avatar
ironman ironman is offline
What is the part number of the new part that you ordered?
Old 10-28-2024, 08:34 AM
Default Part number
(547631-R2)that was the release lever. I’m looking for (544133-R3) this is the rod. Everywhere I look says it’s unavailable, but I have found a couple of narrow frame style levers and rods but idk if they will work.
Old 10-28-2024, 08:47 AM
The rod is nothing more than a length of threaded rod with a 90* bend on one end IIRC. Easy enough to fabricate.
The levers are available from CCS, see banner up top this page.
He has the rod as well
NOS Clutch brake release rod PN/ IH-544133-R3
Fits 86, 108, 128, 800, 1000, 1200 with (Tractors w/caliper brakes)
IH 544133 R3
Old 10-28-2024, 09:13 AM
Default Thanks
Thank you guys, I’m pretty good when it comes to the engine side of things but the other is a little tricky just because all the missing parts now I just sit back and wait on all parts to arrive!!
Old 10-28-2024, 09:20 AM
Billy-O's Avatar
Billy-O Billy-O is offline
For your information: The rod from narrow frame is a different part number than that of your 128. A rod for124 narrow frame uses 393124-R1...... whereas you have 544133-R3. While the numbers are different, I can't tell you whether if they can be interchangeable one way or the other.
Plow blade
#2 Cart
QA36 snowthower
Old 10-28-2024, 01:29 PM
ironman's Avatar
Maybe this will help you....
I have a 1200 which uses the same rod as your 128
A NF rod will not work because the return spring is attached at the angle as shown in pics and the NF rod is does not have enough length going through the arm to accommodate the spring.
