Old 03-21-2025, 05:45 PM
Jhbrooks Jhbrooks is offline
Default GTX2154LE STEERING Issue
Working on this tractor and power steering not working. Thinking it might be the motor. What is the best way to change it?
Old 03-21-2025, 06:48 PM
dieselbob69 dieselbob69 is offline
Need to take steering wheel off, then the black surround. Disconnect the parking brake, unplug all electrical connectors. One screw in each side at bottom just above your foot on outside. Grab the tilt handle plastic and pull it off with some pliers/vise grips
Old 03-23-2025, 12:19 PM
Best way is to remove the whole assembly from tractor. That way it gives you a chance to clean up in area and make sure housing assembly that the gear attaches to on bottom accepts grease. I decided to go with manual steering on mine. You can either take gear off motor and reassemble, or leave motor off and make a cover and some RTV where motor was. I may have a used motor, need to test it. I think something was wonky in the electronic part of system as it wasn’t steering properly, and not gonna spend over $1k for repair kit…
