Old 01-09-2011, 03:25 PM
Patrick51 Patrick51 is offline
Default QA-36 throws chain
Got a QA-36 snowthrower mounted on a Model 1450. Got The thrower used, missing connecting link on chain. Got connector links from central tractor, they wouldn't hold. Got connector links from cub dealer, they wont hold. The chain and sprokets do not appear to be worn badly. Is the inherent design poor, having the chain next to the auger, exposed to the snow and gravel that churns through? I think that stones are getting under chain and popping the connector link off.
Any help would be appreciated.
Old 01-09-2011, 03:47 PM
NOPE
How about some pictures of this chain situation...
Old 01-09-2011, 04:41 PM
Originally Posted by Patrick51 View Post
Got a QA-36 snowthrower mounted on a Model 1450. Got The thrower used, missing connecting link on chain. Got connector links from central tractor, they wouldn't hold. Got connector links from cub dealer, they wont hold. The chain and sprokets do not apprar to be worn badly. Is the inherent design poor, having the chain next to the auger, exposed to the snow and gravel that churns through? I think that stones are getting under chain and popping the connector link off.
Make sure you are putting the clip for the master link with the open end trailing the direction of travel.
If not, the snow/ice will peel the spring clip off and the master link will come apart.
Also the chain needs to be snug, but not tight.
It should have a very slight sag at it's TIGHEST point
Old 01-09-2011, 06:03 PM
Default Thanks Ol George!
OH! Thanks so much, I can't believe I didn't think of the direction of travel. I feel stupid right now, I don't remember which way I put on the clip, but I bet it was backwards.
