Old 05-07-2025, 05:23 PM
440SixPack 440SixPack is offline
Default M18 Jugs
Looking at a set of jugs for my M18 in a 1872 Super Garden tractor. I found a decent set but they are for a MV18 will they fit on a M18 I have heard differing opinions. Thanks
Old 05-08-2025, 08:08 AM
Long story short:
yes and no,
yes they will "fit" but they have drilled holes for oil drain back to crankcase, because of the vertical application.
What is wrong with the original jugs that they need replaced?
And you do know you will have to "adjust" the valve clearance by grinding the valve stems when jugs are swapped.
Old 05-10-2025, 11:01 AM
Will the oil drain back holes cause problems on a horizontal application? The jugs I purchased do not appear to have a ridge on them so I purchased standard rings to go with my pistons just to get it going short term. I have also bought .020 over rings and pistons for my jugs. Then once apart I can get them bored. They have so much blow by right now that it blew out the rear main seal.
I did not know about needing to grind the valves for adjustment my old 12 horse had adjustable lifters.
