I would like to install a 3rd hydraulic valve on a 2182. I believe I have the parts to do so including the replacement upper line although I don't know if this can be done easily having a radiator and power steering to deal with. The radiator makes it a challenge to get my hands in there to do any measuring and to see if the lower hydraulic line will have to be bent or will hit the dash tower. Any help would be very much appreciated.
I don't think there was ever a kit to install a third valve in the cyclops series. The metal dash tower is clearly designed to handle three valves in a stack.
I don't see that any changes need to be made to the upper valve and its connections, if you already have the second valve installed. The new lower valve is a different story. You will probably have to fabricate a hose from the bottom of the valve to the AUX line on the power steering pump. I don't think the radiator will get in the way since all the hydraulic stuff is angled down and away from the radiator. It will be a tight fit however. I hope you get it to work.
2364i (1541) Kohler ECH23 Power Steering 54" Deck 451 Snow Blower 42" Plow |
![]() Quote:
0riginal, 60 RER, 70, 106, 1450, 2182, 3208, XT3GSX & SX54 Z Force |
