Old 06-19-2025, 09:57 PM
apex944's Avatar
apex944 apex944 is offline
Default 2 GT2000s with different enignes?
I got a deal on a second Cub 2000GT
Both appear to have the Kohler Command CH640 as expected.
However the air filter cover on one says Command PRO 20 while the other says Command 20. I did a little googling and supposedly the "Pro" is for commercial or high-demand applications. Crank and bearings are beefier, cooling fins are larger etc etc. I've never heard of this. Is it correct?
SN#s are:
PS-CH640-3100
PS-CH640-3051
- Bill
Cub Cadet GT 2000
gone but not forgotten:
Cub Cadet 1000
Cub Cadet 1650
Old 06-19-2025, 10:44 PM
EternalArianne EternalArianne is offline
I noticed this back when I had a 2155. I think all "Command" engines are "Command Pro" its just different naming based on the year? I'm not exactly sure and maybe someone else could chime in, but I'm pretty sure they are the same? Command is the commercial engine and Courage is the consumer?
Old 06-20-2025, 03:36 PM
apex944's Avatar
OK that makes sense give the additional reading I did later. thx!
- Bill
Cub Cadet GT 2000
Cub Cadet 1000
Cub Cadet 1650
Old 06-20-2025, 07:57 PM
Ozcub's Avatar
Ozcub Ozcub is offline
You are correct Apex944 the Command is the normal engine the Command Pro is a beefed up version
Have a Kohler brochure detailing the differences
Oz
Old 06-21-2025, 12:37 PM
apex944's Avatar
- Bill
Cub Cadet GT 2000
Cub Cadet 1000
Cub Cadet 1650
Old 06-21-2025, 07:43 PM
Ozcub's Avatar
Originally Posted by apex944 View Post
If you are perplexed PM me I can send a copy of the brochure to remove your quandary
Oz
Old 06-24-2025, 10:27 AM
apex944's Avatar
Not perplexed if the info were consistent.
I have seen docs saying your info is correct, and then I also have seen where all CH640 Kohlers had the same parts. Maybe it depends on the year as I have not seen "updates by year" info.
- Bill
Cub Cadet GT 2000
Cub Cadet 1000
Cub Cadet 1650
Old 06-24-2025, 10:59 AM
ironman's Avatar
ironman ironman is offline
I asked Microsoft's Copilot this question....
In Kohler gasoline engines, is there a difference between the Command model and the Command Pro model?
FWIW here is the answer....
Yes, there are some notable differences between the Kohler Command and Command Pro gasoline engines, especially in the V-Twin models like the 18, 20, 23, and 25 HP versions.
The Command Pro engines are essentially upgraded versions of the standard Command line. Here’s what sets them apart:
- Larger air and oil filters, which improve filtration and extend maintenance intervals.
- Higher oil capacity, thanks to the larger oil filter.
- High-efficiency cooling fan and screen, which help in demanding, high-heat environments.
- PTO sleeve bearing, useful in applications with higher side loads.
- High-performance spark plugs and a few cosmetic touches like a yellow oil cap and dipstick.
Old 06-24-2025, 05:43 PM
Ozcub's Avatar
Hey Ironman , that is exactly what the brochure says but it has pictures (lol)
Oz
Old 06-27-2025, 11:31 AM
apex944's Avatar
Thumbs up
thx guys,
... so the info about beefier crank bearings and larger cooling fins was incorrect.
I assume the larger oil filter has the same base and threads?
> High-efficiency cooling fan and screen.
Can this be easily swapped between std & pro?
Same question
Also, any idea on the exhaust question from my other post?
https://www.onlycubcadets.net/forum/...ad.php?t=63194
both are CH640s, but quite a large difference in pipe size. 2013 'Std' has the large pipe and the 2011 'pro' has the small pipe.
Also noticed the hinges for the engine cover are modified on the one with the large pipe (2013)
- Bill
Cub Cadet GT 2000
Cub Cadet 1000
Cub Cadet 1650
