First,I’m very new to this and my first Cub. My new to me 149 seems to run quite well with the exception of the 38 inch mower deck. I hope to use this as my cabin mower starting next year. My goal is to make it as reliable as is possible for a 50 year old mower before bringing it up north where I have limited tools etc. That said, this may be a somewhat stupid question but are their items on the tractor/mower deck that seam to be typical trouble spots to check out? If there are old threads that might address this could you help me find them? Thank you. John in Minnesota
Hello John, welcome aboard.
You cannot go wrong by starting with the owners manual; has the recommended regular maintenance items & lubrication points for both the tractor and mower. Changing the fluids and filters right away is a high priority for me; never know what is in there unless you already know with the previous owner & the machine. While working through the manual's recommended maintenance, be on the lookout for worn or damaged parts. If you did not get the manual with your machine, there is a scan here on the forum in the Resources / Technical Library - Tractors section: Fourth page 'Manual - Operators 1x8/9 Series' Best regards, Gregg
-Gregg The 125: Works the snow & grass The "6:15" (Frankenstein 125/105/?): Misc. projects testbed |
Thank you Greg. I did get reproduced manuals, good suggestion.
I have always found, enjoyed, when I got a new to me machine.
Just start going through it. Not with major repairs in mind but major maintenance. Most all of these tractors get neglected to a degree. Examples might be cleaning the fuel system. Take a good look at your wiring, might be simple connections that look corroded. Good time to brighten em up. All linkages spiffed up and a little silicone to make them move smooth. All kinds a things to learn just dinking around. Kinda fun to just start reading threads of all kinds pertaining to your machine. Enjoy your first Cub. Ken |
The PTO clutch and driveshaft are things that should be inspected and possibly rebuilt. The PTO clutch disc and bearing are wear items.
The driveline has several wear points. The front hub wears from the dowel pin in the driveshaft. The dowel pin can wallow the hole in the driveshaft and fall out. Mine did this and I added a 1/4” set screw to the end of the driveshaft to retain the pin. The rear coupler and end of the driveshaft wear allowing the shaft to wobble and the rag joint usually needs replaced.
Adam 1964 Model 100 w/ K301 12hp and custom hydraulics 1972 Model 149 turned 129 w/ K301 12hp, triple hydraulics, 66 series clone |
![]() Quote:
The mower deck is the most abused and worn part of the mower, so if you put some good effort into making sure it works and don't let the blades get unbalanced it will serve you much longer. As long as you regularly grease them the bearings should last for ages. My grandpa had one that I used up into the early 2000's and those bearings where never replaced. Just a couple pumps of grease every couple times you take it out to use it.
1450- 44A deck,QA-36 snowthrower, 42in front blade No.2 Tiller 70- 38in deck, 42 inch deck |
Welcome John TV. When I first saw your post about the "Order of Operations", I thought about my Algebra I class and the "Order of Operations". It made me laugh because the teacher would tell us, "Please Excuse My Dear Aunt Sally", which was an pneumonic device for remembering to do "Parentheses-Exponents-Multiplication-Division-Addition-Subtraction". We were tough guys, so we made learning tough to her dismay and changed it to "Please Execute My Dog And Sister"
![]() Congratulations, you purchased a very solid cub cadet that you will find more utility with than just mowing around the cabin. It will haul wood, help pull logs, garden, remove snow, move mulch, gravel, etc. I have owned several 149's and one thing I noticed is what IHinIN mentioned was the PTO clutch. If your 149 is an older model 149, then it will not have the safety brake on the front PTO clutch that was put on in 1974. If it predates this modification, then inspect and likely replace the wear button (cost about $15 DIY). The brake had a large round pad on it as a safety modification. Others have given you really good, sound advice already, so I would advise you to look into what they have stated, but I would also add that if you are taking your cub 149 to any shop for work, then I would have them remove the balance gears in the engine. They are a ticking time bomb. The side effect is that your cub will shake or shimmy just a little bit more than normal, but nothing bad at all. A well serviced machine will see you through another 50 years of service! Cub Cadet 123
Still don't know what I'm doing in OHIO?.....If you find me, then please point me back toward INDIANA. ![]() |
