Old 08-11-2025, 10:49 PM
John TV John TV is offline
Default Hydro Trunion Repair 149
After inspecting the spring set up on my hydro trunion, I need to proceed with repairs. I believe I have read most of the info on the repairs but I’m am struggling to figure out how to remove the control bar from the transmission. In looking at a transmission manual they show what looks like some snap ring groves but other diagrams do not show that.
I’m not that experienced with mechanical items so I’m hoping you all might be able to give me some pointers. I’ll attempt to add pictures of what I’m talking about.
Thanks. John in Mn
Old 08-11-2025, 10:51 PM
The part is number 49 on above diagram
Old 08-11-2025, 11:00 PM
The part is #49
Old 08-12-2025, 07:50 AM
Why do you need to remove it? There are a few sponsors at the top of the page that make repair kits for these that you repair in place. I have welded a few of mine without removing.
Old 08-12-2025, 09:25 AM
green407's Avatar
green407 green407 is offline
There's no need to remove it. Just build it up slowly leaving lots of time for the heat to dissipate.
128 X 2, 129, 149, 1250, 1450 x 2
Old 08-12-2025, 09:46 AM
I’ve been looking at several sources that show repairing while on the tractor. I seem to be “search” challenged as I just saw these this morning. Being new to this I find that first looking up the correct part name makes the search much easier…duh?
Now I’m wondering if the damper plate also could use some adjustment. How much “play” should there be in the spring slot on the damper plate?
I’m waiting on shims to arrive and should likely order new springs too.
Thanks for everyone’s suggestions.
Old 08-12-2025, 11:38 AM
Paul_CC149 Paul_CC149 is online now
Old 08-12-2025, 11:46 AM
ironman's Avatar
ironman ironman is offline
See this thread, Post #9.
Although I wouldn't hack up a hydro,
the piece shouldn't be that hard to make with a hacksaw, a drill, and a file.
https://www.onlycubcadets.net/forum/...ad.php?t=63311
Old 08-12-2025, 02:23 PM
green407's Avatar
Let's see if I can come up with a few "how to's"
https://www.onlycubcadets.net/forum/...hlight=Trunion
https://www.onlycubcadets.net/forum/...hlight=trunion
https://www.onlycubcadets.net/forum/...trunion&page=2
https://www.onlycubcadets.net/forum/...04&postcount=6
So here's a few links, some are better then others but hopefully they'll gave you the info you need/require to make the best repair.
Old 08-12-2025, 03:56 PM
CubDieselFan's Avatar
See post #3 in this thread....
https://onlycubcadets.net/forum/showthread.php?t=63289
