Old 08-15-2025, 06:19 PM
rsshallop rsshallop is offline
I've given my 108 new rubber all around (the old tires were the original ones) and replaced the bolts I'm using for wheel studs on the rear hubs with ones I modified by filing down the heads of the new bolts. Radioguy41 kindly pointed out that my first attempt last year left the end of the bolts recessed in the lug nuts. The new tires are all tubed and inflated to 18psi, which I think puts me in the ball park on where they should be.
Cub Cadet 108 / no mowing deck
42" snow blade
Old 08-18-2025, 08:13 AM
jaynjeep's Avatar
jaynjeep jaynjeep is offline
Looks great!! let the psi down some they will pull and ride much better.. better yet liquid fill them and run 8 to 10 psi, you won''t believe how much better they ride and pull..
Jay
Proud owner of the following:
Old 08-18-2025, 10:11 AM
Radioguy41's Avatar
Radioguy41 Radioguy41 is offline
Looks good!
2005 CC GT2544
1980 IH CC 782
1957 Cub Lo-Boy
1993 Craftsman LT4000
Old 08-18-2025, 04:37 PM
Thanks Jay, I'll drop them down some more to 14psi and keep the liquid fill advise in mind.
Ross
42" snow blade
Old 08-18-2025, 10:43 PM
Jb4249 Jb4249 is offline
Default 1100
I pulled the old Briggs, possibly to rebuild. And pressure washed the 1100
