Old 08-27-2025, 07:46 PM
codycub86 codycub86 is offline
Default New member neeed help
hi i am a new cub owner i inherited what i thought was a 126 but as i ran the serial number i tguess its a 86 and the motor dosnt have a tag on it but it says 14hp kohler anyways heres some pics of the tractor i popped the head off and found burnt head gasket it ran but not right
Old 08-27-2025, 08:18 PM
green407's Avatar
green407 green407 is offline
Looks like a 108 that got an engine transplant.
128 X 2, 129, 149, 1250, 1450 x 2
Old 08-28-2025, 08:46 PM
what makes u say that the seriaL NUMBER COMES BACK AHN 86
Old 08-28-2025, 11:17 PM
Billy-O's Avatar
Billy-O Billy-O is offline
You got a wide frame.... the 126 was a narrow frame. Looks like you got a mish mash of Cub Cadet tractors put together.
Plow blade
#2 Cart
QA36 snowthower
Old 08-29-2025, 08:22 AM
IHCubCadet147's Avatar
Definitely not a 126, someone put the wrong decals on it. An 86, 108, and 128 are all the same tractors, only difference being the engines, 8 hp K181, 10 hp K241, and 12 hp K301. It most likely is an 86, and someone put a larger engine in it, a 14 hp K321 would be a direct fit, but they never came from the factory in a gear drive tractor. Now, if your serial number is on the transmission, it is possible that someone swapped that out with one from another tractor. If that’s the case, they most likely didn’t change the tag, and there is no way to tell exactly what your tractor started out as. It is definitely an 86, 108, or 128 though.
Old 09-08-2025, 12:20 AM
Something is VERY STRANGE about your engine or else your 2nd picture is reversed. It shows your carb set up on the driver's RHS and your exhaust exiting the driver's LHS. Hmmmm....but your first picture shows the carb on the correct side. Cornfusing???
Old 09-08-2025, 09:21 AM
ironman's Avatar
ironman ironman is offline
3rd pic reversed also. Keyswitch & solenoid on wong side. Or it's a British Cub?
