Old 10-06-2025, 08:44 PM
termilvr7 termilvr7 is offline
Default Plow Lift Bracket Interference
I just got a 719-3093 lift bracket for a future plow purchase and went to install. I noticed it is contacting the bolt heads that hold the lift bushing to the frame. This is not allowing it to be fully installed so the bolts can pass through. Is there something I am missing here?
Old 10-06-2025, 08:59 PM
Is that on backwards?
Up to 534 and counting...
Old 10-06-2025, 09:26 PM
I am not sure how it could go on the other way since the hole on this side is not large enough and only clearance for a grease gun.
Old 10-06-2025, 10:30 PM
That is the correct way
Old 10-06-2025, 10:42 PM
Is there something else that could be causing my issue that you can see? Different screws required for the bearing, incorrectly drilled holes in the lift bracket?
Old 10-07-2025, 09:37 AM
Move it out about 1/8"
Old 10-07-2025, 07:11 PM
Then the mounting bolts won't be able to be installed. In their current state with the bracket rubbing on the bearing bolt heads they cant be installed.
Old 10-07-2025, 08:05 PM
Oh well, I never had an issue with mounting it. You may have to get some pan head bolts and install them.
Old 10-07-2025, 09:53 PM
brudder brudder is offline
Yep, pan head bolts or I have ground down the hex head and coated it with zinc rich paint. I'd use some antiseize on your socket head screws and the hex head bolts if you go that route because you wont be able to put a lot of torque on them in the future.
Old 10-08-2025, 07:31 AM
ironman's Avatar
ironman ironman is offline
I would remove one of those bolts and have a looksee that maybe the hole is chamferred for a flat head bolt.
Even if not, you can countersink the hole and put in new flat head bolts. Eezee Pezee!
