Old 10-11-2025, 03:56 PM
SDBOB SDBOB is offline
Default Cyclops Nose plastic question
The screws-bolts that hold the hood to front grille. When I removed the nose to fix some cracks in the grille the screws- bolts came out of the hood plastic. The screw end seems very short into plastic. Should i use some kind of adhesive to fasten these screws to hood better? I'm going to make a thin wrench to hold these screws so they dont come out again when installing the 7/16 headed nut. The nuts seem tight almost like a crimp nut. Slow progress. Thanks Bob
Old 10-19-2025, 05:47 PM
garydee's Avatar
garydee garydee is offline
Default Cyclops nose plastic question
I have 3 cyclops tractors that I really enjoy using since I restored them. The plastic hood, grille and side panels are the nemesis of all the cyclops models. It is very hard to fix the panels, especially where screws/studs and pins are located. As you may know, the plastic parts are costly to replace as well.
Perhaps you could try some 2 part epoxy to fill the holes and then re-drill and tap them to use machine type bolts. As I recall the grill hinge is held in place with coarse sheet metal type screws. If you fill the holes, then drill and tap them using short machine thread bolts, you will be less likely to mess up the plastic any worse than it is.
The 4 studs on the hood panel can be done the same way. Or you could try some superglue on these if the holes are not too bad. It is tedious to say the least to fix the plastic parts. Getting the hood to fit correctly is also a frustrating.
Good luck!
Old 10-21-2025, 10:51 AM
Thank you. Just starting to learn about the cyclops plastic.
Old 10-21-2025, 01:28 PM
There is a product called "Plast-Aid"
Give that a look.
Check your PM's
I used it to fix panels on a 2182 a few years back.
Works great.
https://www.poolwarehouse.com/shop/p...All%20Products
Old 10-22-2025, 07:15 AM
Got it thanks for the information. I had bought epoxy. I'm making sheetmetal plates to reenforce where nose bolts to frame. One side is perfect other side has half of the tab missing.learning.
Old 10-29-2025, 07:50 PM
Oldschoolaccord Oldschoolaccord is offline
Mackland cadets on you tube has videos on repairing the nose pieces
Old 10-30-2025, 03:17 PM
garydee's Avatar
Default Cyclops tractors
I have watched several "Mackland Cadets" videos since finding him on Youtube.
He does a variety of repairs and parts removals, mostly on cyclops style tractors. He seems quite knowledgeable and intuitive when it comes to fixing/repairing common problems.
Jimmy said he is located about an hour south of Buffalo for those who are interested in getting parts. He considers himself to be primarily in the tractor salvage business, removing lots of useful parts from tractors to sell to those in need. Seems like a nice guy...
I wonder if he knows about the only cub cadets website?
Old 10-30-2025, 07:02 PM
ccguy's Avatar
ccguy ccguy is offline
The plastic panels on the Cyclops Series of tractors are made of Xenoy which is a thermoplastic consisting of polyester and polycarbonate. (Green machines use the same material) The best urethane adhesives to use are 3M Semi-Rigid Parts Repair and J-B Weld Plastic Bonder.
INTERNATIONAL HARVESTER
- A Great Farm Heritage Comes Home.
1811/682/782/1440/IH #4/IH QA 42"
Old 10-31-2025, 11:27 AM
garydee's Avatar
Default Cyclops...
Good to know...BTW was it GE (General Electric) that developed Xenoy?
Old 10-31-2025, 05:36 PM
ccguy's Avatar
GE Plastics developed Xenoy in 1984 for use in the automotive industry. GE sold their plastics division to Sabic.
