Old 11-02-2025, 11:45 AM
Is there anything missing here for the ps install?
Old 11-02-2025, 01:21 PM
Paul_CC149 Paul_CC149 is offline
If you are planning to use AUX hydro port for PS in conjunction with lift cylinder, you will need T- adapter for return (low pressure) line.
Old 11-02-2025, 03:34 PM
garydee's Avatar
garydee garydee is offline
Default Power steering...
If any members have ideas as to how to make this work on a 1641, please chime in. I'm not sure if the hydro pump on a 1641 has an aux out to use for the steering.
My plan was just to use the send line (from the lift valve) going to the power steering unit inlet first with a return line to the hydro. The aux from the power steering unit would then go to the lift valve with the return from the lift valve tee-ing into the return line from the steering unit that is already connected to the pump. The R and L hoses going to the steering cylinder. Hopefully there will be enough pressure to make this work. Steering might be a little weak if using the lift valve at the same time.
With any luck I will be able to couple some of the existing steel hydraulic lines which have some tight bends to make this work.
If my ideas don't sound quite right, please let me know what you think needs to be changed. Help from the members is always appreciated!
Old 11-02-2025, 03:41 PM
garydee's Avatar
Default Powersteering...
Oak, I think one additional line with 2 sharp bends, that connects to the power steering unit is missing. Should be 3 lines with sharp 180 degree bends connecting to the steering unit in total.
Thanks!
Old 11-02-2025, 08:56 PM
SS5150's Avatar
SS5150 SS5150 is offline
I'm looking for that line on the right side of Oak's picture if anyone has one available.
RUN IN THE RED
1872 project
Cub Cadet Pro Z 560 L
Old 11-03-2025, 08:51 AM
Frank1541 Frank1541 is offline
I think the Gerotor on the 1641 might be too small to handle power steering. The Gerotor on the 3000 series looks to be more robust. I wonder if the 3000 Gerotor could be fit onto the 1641 Hydro?
I have seen Hydros from the power steering equipped tractors sell for reasonable prices lately. Maybe one of them and a custom drive shaft.
2364i (1541)
Kohler ECH23
Power Steering
54" Deck
451 Snow Blower
42" Plow
Old 11-03-2025, 09:32 AM
garydee's Avatar
Another option would be to get a sunstrand rear end from an 1864 or an 1862 with the drive shaft. That would be a direct fit to the 1641 frame. I'm not too familiar with the 3000 series machines to know if anything from them would work on my 1641. Perhaps other members might have additional information on this.
Frank, is there any way to test the flow of the pump on a 1641 to see if power steering is a viable option for my hard steer problem without changing the pump?
Old 11-03-2025, 01:53 PM
garydee's Avatar
I added aux hydraulic connectors to the front for an implement and an additional valve when I restored this 1641. Would it be possible to check the flow by connecting up some lines and a flow device for reading GPM to the front hydraulic connectors?
What kind of device would be used to measure the GPM output of the pump?
Old 11-03-2025, 02:45 PM
Just to let you know, the 1641 does not list a power steering option in the parts list, so you need to find a rear with a sunstrand ported pump. Maybe skinny tires like on a 70, then have the rims accept a 1" bearing. Cheaper than adding power steering.
Up to 534 and counting...
Old 11-03-2025, 02:47 PM
A watch with second hand is a good device, you are looking for GPM --gallon per minute.
Hook up a hose to one of your ports, nothing fancy as you are not building pressure.
Put a clean quart jar in a clean 5 gallon bucket bucket, and count how many seconds it takes to fill the quart jar, then do the math.
no need for a fancy flow meter.
