Old 01-14-2026, 11:37 AM
gkingbing gkingbing is offline
Default CC 1541 Hydro Issue
While topping off the hydro transmission I used a funnel with the spout downsized by inserting a 3 inch piece of clear plastic tubing into the funnel so it would fit into the fill hole....When removing the funnel the clear plastic tubing fell into the fill tube and its gone.....Should I expect the machine to fail as a result of this screw up?????
Old 01-14-2026, 06:06 PM
Billy-O's Avatar
Billy-O Billy-O is online now
I wouldn't take the chance and I would get that tube out.
Plow blade
#2 Cart
QA36 snowthower
Old 01-15-2026, 10:05 AM
Remove the rear cover and get the plastic tube out. It can possibly get into the gears and make a mess out of things.
Old 01-16-2026, 12:55 PM
Default Tube removal
How would I go about getting the tube out?....I may not physically be able to do it.
Old 01-16-2026, 02:59 PM
Remove the filler tube, it unscrews, and you may be able to get it out that way.
Up to 534 and counting...
Old 03-13-2026, 02:56 PM
Default CC 1541 Access the rear transmission plate
Does anyone have a video showing what needs to be removed to access and remove the rear transmission plate...I need to remove a piece of plastic tubing that got into the transmission....Thank you
Old 03-13-2026, 04:07 PM
You can down load the service manual here
https://www.onlycubcadets.net/forum/...439#post537439
