While topping off the hydro transmission I used a funnel with the spout downsized by inserting a 3 inch piece of clear plastic tubing into the funnel so it would fit into the fill hole....When removing the funnel the clear plastic tubing fell into the fill tube and its gone.....Should I expect the machine to fail as a result of this screw up?????
I wouldn't take the chance and I would get that tube out.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
How would I go about getting the tube out?....I may not physically be able to do it.
Remove the filler tube, it unscrews, and you may be able to get it out that way.
Does anyone have a video showing what needs to be removed to access and remove the rear transmission plate...I need to remove a piece of plastic tubing that got into the transmission....Thank you
