Old 03-29-2026, 02:01 PM
Cubcadet782desiel Cubcadet782desiel is offline
Default Cub cadet 782d options?
I have a 1985 cub cadet 782d and I'm wondering what options it could have mine has a deluxe seat with a armrest kit or at least I think the seat has 4 threaded holes in the back and a outline of a plate on the back I looked it up and looks like a armrest kit went there. Next mine has a block heater IH hubcaps and came with a 3 point hitch and #2 rototiller also has a 44c deck. anything else?The seat has the safety switch plug in it too so that's why I'm thinking its og
Old 03-29-2026, 06:01 PM
CubDieselFan's Avatar
That seat was changed by a previous owner. It is not the original seat. Looks like a comfortable seat.
Old 03-29-2026, 07:07 PM
It is I was just wondering because on cub cadet specialties they have a armrest kit that's NOS in a IH box and in the kit there is a plate for the back of the seat and there is a outline of a piece of steel that used to be there are there any options I'm missing I know I'm missing the factory battery warmer that was a option but anything else in terms of being on the tractor itself?
Old 04-03-2026, 07:59 PM
Jumper Jumper is offline
how about front and rear quick connect hydraulics ?
Old 04-04-2026, 10:00 AM
These were some options, some are services kits
battery warmer kit.
grass deflector kit.
negative battery cable kit.
diesel heat kit
Up to 534 and counting...
Old 04-04-2026, 12:07 PM
Farmall450's Avatar
battery warmer kit.
diesel heat kit
Is the metal shield on a 44/52C deck the grass deflector kit?
I've got one on a 44C.
Old 04-04-2026, 12:51 PM
It goes here.
Old 04-04-2026, 10:27 PM
Farmall450's Avatar
It goes here.
Ah, I was thinking of the one bolted in the deck chute.
Old 04-07-2026, 08:00 PM
battery warmer kit.
diesel heat kit
whare does the extra ground go don't have any of those I think I have front remotes and hubcaps that's about it I think
Old 04-07-2026, 08:23 PM
spndncash spndncash is offline
if the seat is embossed with cub cadet in the back cushion then it is likely the seat for their ZTR's - arm rests were on every one ever I had. four bolts on the back of the seat and fold up arm rests.
