Old 06-14-2009, 09:29 PM
CMJAnew CMJAnew is offline
Thanks so much. I'll let you know how bad I mess it up. LOL
Old 06-15-2009, 09:07 AM
murphycc
Guest
Posts: n/a
http://www.kohlerengines.com/onlinec.../52_590_02.pdf
Here is the manual.
Scott
Old 06-15-2009, 09:03 PM
Awesome. Thanks ever so much "all" of you. I'm getting more confident every day.
Old 06-16-2009, 06:49 AM
Can anyone share the specific part number of the seal I'll be needing to make this repair?
Thanks Again
Old 06-16-2009, 07:37 AM
CM:
As found in the Parts Manual.....
Old 06-16-2009, 08:00 AM
Again - ThanksMuch,
Old 06-16-2009, 08:35 AM
HOLD UP!
He needs part #10, NOT part #20 in there....Roland, you showed the flywheel end seal. He needs the PTO end crank seal.
KH-52-032-08
Old 06-16-2009, 08:55 AM
CM:
Matt is right. I got the wrong end of the motor. My bad.
Old 06-17-2009, 05:39 AM
Beggers can't be choosy. Just imagine me trying to figure out why the part I was attempting to install looked very little like the part removed. LOL It would not have been pretty.
Is there a link to the manual you folks are sharing here? The one received earlier in this thread doesn't include the parts breakouts.
Thanks
Old 06-17-2009, 07:18 AM
CM:
You can get a Service Manual from here.... Manual
You can look up parts from two sources...
(A) Get your Kohler Model and Spec number and go here.......Parts and login as a "Guest"
(B) Click on this link with your tractor model number.... Cub Cadet
