Old 07-22-2026, 02:23 AM
kyron4 kyron4 is offline
Default LT1045 Hydro-Gear fluid change ?
I have a 2006 Cub LT1045 with a Hydro-Gear transmission. I [plan to change the fluid. I'm told Syn. 20w50 is the recommended oil, is this correct ?Do you fill it to the top of the fill plug hole for full ? What is the purpose of the plastic "reservoir" on top of the trans. ? Is it to be filled full also ? Any advice welcomed. -thank you
Old 07-22-2026, 07:06 AM
evhevh evhevh is offline
Take a look here. I think you will find what you need:
https://www.hydro-gear.com/support/
Old 07-23-2026, 01:49 AM
Thanks! I'll look for my model number and see if they have a manual.
Old 07-24-2026, 06:59 AM
Sergeant's Avatar
Sergeant Sergeant is offline
Yes that is the correct fluid for Your Hydro-Gear and the capacity is 79 fl. oz.
You Have a Model 310-0510
Old 07-26-2026, 02:03 AM
Ozcub's Avatar
Ozcub Ozcub is offline
Do not put all 79 fl oz in at once put maybe 65 in and start checking dipstick for level , slowly continue adding a bit at a time always checking level
Old 08-21-2026, 04:58 AM
Yes , you are correct. I found the tag on the trans axle.
Old 08-21-2026, 04:59 AM
There is no dipstick, only a fill hole and expansion tank.
