Old 01-12-2011, 11:47 AM
jfinney's Avatar
jfinney jfinney is offline
Default So much better!!!
Over the last week I took apart my QA42A, sanded the auger, housing and chute and repainted it with EZ slide. I then mounted it on my 149 and waited for snow. Today was my first opportunity to use it. We got 5 inches of very light, fluffy snow, so I gave it a try. It works so much better than before. Previously, even with a dry snow, the snow would accumulate on the rusty areas of my housing, auger and chute and the thrower would plug up. Now, I had no such problem. I even took it off roading in my yard, where we had about 3 inches of hard, packed snow prior to the light, fluffy snow, and it just ate it up and spit it out! Cleaning my driveway with the 149 and snowthrower went much faster than it usually does with my Farmall Cub and snow plow. It does a cleaner job also. The only problem I still have is that the 149 needs the trunion repaired. When I move the hydro lever it takes a little bit to catch up to the movement and by then I may be going faster than I wanted. It also does a very poor job of maintaining speed on a hill, to the point that I will either come to a stop, or I have to constantly adjust the hydro lever. Anyway, my point was that the 149 and newly painted QA42A did a great job! I'll be curious to see how it does with a wetter snow. I took photos of my tractor after the fact...my wife doesn't do cold, or early mornings, so I had no one to take action shots or videos! Hope you all enjoyed the snow as much as I did.
Jason
Old 01-12-2011, 12:20 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
I have to beg n ple to get my wife to take any pics or vids . she isn't overly fond of my cub addiction.:biggrin2.gif:
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 01-12-2011, 02:46 PM
cubcadet100's Avatar
cubcadet100 cubcadet100 is offline
I heard that, my girlfreind inst fond of my addiction either i think shes another cub away from having me put in a nut house. lol
Original, 100 with fenders creeper lights 3pt spring asst., 147 with electric lift IH hubcaps, 102, 126, 682 QA36 snow blower, 2 Dozer blades, Haban sickle bar, John Deere 60 Lawn tractor with deck and snow plow, 1962 Fordson super major backhoe, 1941 Allis Chalmers WC
Old 01-12-2011, 04:11 PM
TEET's Avatar
TEET TEET is offline
Glad to hear its working better for you Jason! I painted the inside of my old qa42a that I sold a while back, and it made a world of difference. I had to re-apply some mid season as it tends to wear off with use, but man what a difference.
I'm tempted to paint the plow surface of my 54" plow with ez-slide....but something about the black..I wonder if it can be found in other colors, or tintable?
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-12-2011, 04:27 PM
Considering the graphite in the EZ-slide is dark gray/black, probably not.
Old 01-12-2011, 04:45 PM
TEET's Avatar
Thanks Matt..gotta ruin my dreams of having an IH white ez-slide coating....lol
If you wanna slide..then black it is!
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-12-2011, 10:04 PM
william1041200's Avatar
Default I wonder if this may respark your dream...
http://www.westmarine.com/1/1/332--b...ige-quart.html
Old 01-12-2011, 10:22 PM
TEET's Avatar
Originally Posted by william1041200 View Post
hmm...respark my dream...I like that..lol
Interesting stuff.....I wonder if it has the same general specs and performance as the ez-slide? Sounds like a little research is in order!
Thanks William!! :biggrin2.gif:
Jeff (teet)
CCC 1211
71
127
102
122
1962 Original
Old 01-17-2011, 10:28 AM
cdlong's Avatar
cdlong cdlong is offline
Used E Z Slide,(3 coats each attachment), on 42 & 54" blades and the QA36A chute. Snow still sticks to the blades. Haven't tried the snowthrower yet.
Papaw
1984 CCC 582 w/ creeper, 42" blade, 44C deck, 220# wheel weights, 2 link chains & adjusters, Spring assist lift.
Old 01-17-2011, 11:41 AM
Iowa Farmboy Iowa Farmboy is offline
I sprayed multiple coats of slip plate on my plow truck blade. The snow does still stick as much as bare steel. To do it over again I would use reg. paint with multiple coats of clear coat with wax. I think that would work better.
Josh
1989 SGT 2072 (restored)
60"Haban Deck, 54 "Haban Blade, 48" Cub Cadet Tiller, 12" Brinly Cat O plow, 48" Cat O landscape rake
Cub 128 with creeper and rear PTO with reverser(next project)
IH built 682 and 782 that will combine to make one
