Keep us informed everybody likes happy endings and this "movie" is interesting.
1572, 1864 x2, 1810 x2, 1863 & GT1554(Dad's Ole Mowers), 1811,782D, 1872 x2, 782DT(Sold), 3235, 1860, 1772 with 3-point and Turbo. |
What is the model # of the Kawasaki engine? Just curious since search 24 hp kawasaki finds prices ranging $1700 and way up.
Two 125's and a 124 all with 42" decks Plow blade #2 Cart QA36 snowthower |
Hate to burst your bubble and while I'm new here posting, I've been working on anything with a motor for many years as a DiY. Blowing out ANY smoke is not good. If gas was leaking into the motor and thinning out the oil, then those rings have seen their life span. You can change out carbs, do a valve job with new head gaskets, change the oil, every cheap option in the book, but it still won't replace your problem. New Rings needed, along with new crank rod bearings, as I bet the gas also thinned the oil enough that you'll soon have rod knock if those lower end bearings aren't changed too, to bring back the proper bearing spec.
If you say you have a mechanic that can rebuild to within what an online seller can get you an engine for, I'd go with that good mechanic. This way, if problems crop up within a warranty, you have someone close by that can correct the problem quickly by laying eyes on to fix, rather than trying to go thru someone hundreds/thousand of miles away. You can also negotiate with your local mechanic about how you might want done with your motor to make work like new. I just recently got a 2008 Recon Tank, but has 25hp Kohler motor on it. They're worth keeping and made to work. |
