Old 01-22-2011, 06:00 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default cold natured kohler
It does seem like it whine when you press on the foot brake. that makes since thats its harder to start because the oil is thicker. Is there any way to adjust the hydro lever so when you push on the foot pedal so it will go into neutral
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 01-22-2011, 06:30 PM
Go to this link and download the manual and go thru it real good. It will explain how to adjust the hydro linkages.
http://ccmanuals.info/pdf/1x8-9%20&%...e%20Manual.pdf
Old 01-24-2011, 12:10 PM
FFGino FFGino is offline
Default Cold-natured Kohler
I got too busy and didn't get the summer (30w) oil changed in my 1650 and the second time I went to blow snow, it was 3 degrees above zero!! My cub lives in the barn and wasn't interested in turning over...30 minutes later, after firing up the torpedo heater, no problem. Well after finishing the snowblowing, I drained the 30w oil and replaced it with 10w oil, like I SHOULD HAVE sooner. The next time I went to start the 1650, it was -5 degrees. Half throttle and full choke and it didn't turn over more than 3 or 4 times and it was running. The timing, carb, spark plug, and battery are all up to snuff and finally, so is the oil.
Did I get all the egg off of my face??? :biggrin2.gif:
FFGino. Happy Cubbing!!
