Old 01-24-2011, 03:57 PM
Pa Cooner's Avatar
Pa Cooner Pa Cooner is offline
Default Cub Cadet 3235
I recently aquired a 3235 for the ripe old price of hauling it away! Motor was supposedly locked up. Come to find out it had water in one cylinder. Kohler command 23hp. I am currently in the process of repairing the engine, but was wondering if there is any other known problems with these 3000 sereis tractors?
Old 01-25-2011, 07:27 AM
Pa Cooner's Avatar
No responses in 12hrs time is a good thing I suppose. Must not be any major problems!
Old 01-25-2011, 07:50 AM
gcbailey's Avatar
gcbailey gcbailey is offline
the 3000 series is pretty tried and true... I've heard of a few people tearing out the locking differential but by their own admission they were doing things that they should have been using a larger tractor or truck.
Gary
Old 01-25-2011, 07:57 AM
Those big Kohlers are nice, I haven't heard of much going wrong with them.
Old 01-25-2011, 08:26 AM
aagitch's Avatar
aagitch aagitch is offline
Make sure that if it has the differential lock option, you don't engage it while it's moving. That's how they're being damaged, owners not reading the manual.
Old 01-25-2011, 10:44 AM
Pa Cooner's Avatar
I will keep that in mind! Once I get it up and running I have a snowplow off a different cub that Im gonna fabricate to fit till I can afford and find a the correct front hitch and plow setup. Unfortunatley this tractor is not equipped with the aux hydraulic ports, so I will be trying to install those also.
Old 01-25-2011, 05:54 PM
gcbailey's Avatar
all the aux ports makes those things super sweet, front, mid, rear... nice.... there's a guy who works with my wife that's got a '04?? with the liquid cooled Kawasaki and he loves it. I think it's got over 800 hours with no issues.
Gary
Old 01-25-2011, 07:34 PM
Yamaguy's Avatar
Yamaguy Yamaguy is offline
I have always wanted a 3000 series Cub, espically a free one! Pics?
Dale
147-Restored___________________882 Diesel
Hydro lift (not installed)___________44" Deck
48" Deck_______________________QA-42a/b Snowthrower
Rear lift ________________________XMW cat-0 rear lift
Model 2 tiller____________________12" cat-0 Brinly plow
Old 01-25-2011, 09:15 PM
Pa Cooner's Avatar
Once I get her together and cleaned up, I will try and get some pics up. It sat outside for several years in the weather, so its a little rough looking. It has somewhere north of 2000 hrs on it right now!
Old 01-26-2011, 01:15 AM
lonnyb's Avatar
lonnyb lonnyb is offline
The 3235 is a good choice, they are a tuff cub, I have had mine for a little over 5 years now and have had a few issues with it.
Bolt worked loose in the ring gear and took out the rearend, hydro line blew under tractor leading up to power steering pump, PTO pully bent.
Changeing the PTO belts is not a fun job.
I have worked mine hard and it still lives on.
Here are a few photos of my work horse
You don't want to break one of the hydraulic cylinders as I found out the hard way, they are quite spendy to replace.
