K321 on a 1450....got a backfire thru the exhaust this morning trying to start it (although it did start) noticed a oil spot on the back side of the muffler the size of a dollar bill, looked like the fins below the head were wet also...can't see any other place this would come from other than the head. I ran it for awhile and seen no leaks. It started lots harder than it normally does. Any ideas?
metalrain |
Sounds like you blew the head gasket...only way to know for sure would be to take the head off and see for yourself.
my cub cadet 100 has a little oil leak at the front of the head. my dad said it was a bad head gasket
Turns out it was more of a "defective" gasket....i did a quick swap of motors yesterday....had a ebay kit head gasket laying around and used that....after i pulled the head off you could tell it was deformed from the start. Put it back together with an OEM gasket...used it for an hour or so and looks like it did the trick....After comparing the two gasket...there is a difference between OEM and aftermarket.
Thanks guys. metalrain |
Rain,
Glad to hear that it was only the head gasket! Matt G. clearly illustrates the difference between OEM and after market gaskets on his website. Great info (as always) and it definitely convinced me to not skimp on those parts. The pennies I can save are certainly not worth the headache of replacing the gasket. |
