Old 02-11-2011, 12:58 PM
JOHN SCHUTTE's Avatar
JOHN SCHUTTE JOHN SCHUTTE is offline
Default K301 Camshaft pin
Has anyone had trouble driving out the camshaft pin to remove the camshaft from the block? I have read the kohler engine manual and it states to drive it out from the pto side towards the flywheel side. Just asking in advance before I attempt to remove it tommorow.
Nemesis
Old 02-11-2011, 01:30 PM
cubs-n-bxrs's Avatar
John once the pin exits the pto side of the block it usually comes out pretty easy. I have only had one give me some grief and that was because the pin was slightly bent.
Old 02-11-2011, 01:44 PM
Thanks for the information Cubs-n-bxrs! I hope mines not bent. It did have some rust in the holes of the block so I shot them with wd-40 hoping it helps.
Nemesis
Old 02-11-2011, 06:03 PM
WD-40 isn't going to do anything because it isn't a penetrating oil. Get some Kroil or PB Blaster...
Old 02-11-2011, 06:30 PM
I have never used penetrating oil to remove a cam pin. A nice size drift punch and a good ball peen hammer and it will come right out.
Old 02-11-2011, 06:33 PM
MrGitrdone41's Avatar
Just use some PB blaster and tap on it with a hammer.
1988 1812,dual ports
1973 108
1968 125
Old 02-11-2011, 08:49 PM
Did two last week. Proper punch and a small 3lb hammer. No problem.
Old 02-12-2011, 10:02 AM
Matt G., where is your proof that WD-40 is not a penetrating oil? Kroil is great stuff, but hard to find. Pb Blaster is good also, I just had WD-40 at the time. I soaked a badly rusted exhaust elbow for 2 days in WD-40. A few taps with a hammer and it was removed unbroken.
This will be the last time I mention a brand name of any product.
Nemesis
Old 02-12-2011, 10:27 AM
It's basically aerosol Kerosene. It's meant to displace water and keep things from rusting, which it does work pretty good for. It is also handy for degreasing stuff. It claims to be a penetrant, this is BS from my experience. Tried it a couple times for that, and it didn't do anything. PB blaster, Liquid Wrench, Kroil, etc. actually work as advertised.
Old 02-12-2011, 10:30 AM
This is from WD-40's web site, FAQ page- "What does WD-40 contain?
While the ingredients in WD-40 are secret, we can tell you what WD-40 does NOT contain. WD-40 does not contain silicone, kerosene, water, wax, graphite, chlorofluorocarbons (CFCs), or any known cancer-causing agents."
Nemesis
