Old 02-14-2011, 12:21 PM
Ray Ray is offline
Default Subframe Measurements Help
Seeings how factory snowplows are as scarce as hens teeth in the Great Northwest I am adapting a newer model snowplow to my 149. My current cobbled up mounting bracket doesn't work well and looks like poo so I'm going to redo it by building me a custom OEM style snowplow subframe.
Could I ask someone that has easy access to their wideframe subframe get me the measurement from the center of the quick attach pins to the bottom of the horizontal arm and also the width & thickness of the metal used in the subframe?
Thanks!
Old 02-14-2011, 04:20 PM
The measurements from my 129 blade frame are as follows:
Center of pin to lower arm: 5 1/2 inches
width of bar: 11/32" Or roughly .34 - .35 depending on rust and paint, LOL.
Thickness of bar top to bottom: 1 3/4 inches. 1.75"
Hope this helps.
Old 02-15-2011, 10:21 AM
Ray Ray is offline
Thanks DX3, really appreciate it!
Old 02-15-2011, 05:29 PM
I don't think you can buy 11/32" steel flat anymore. 3/8 x 1.75" should do just fine.
Old 02-17-2011, 10:08 AM
Ray Ray is offline
Thanks for the measurements guys! Now I have to prep myself for "sticker shock" when I go buy the metal.
