Old 03-07-2011, 01:53 AM
ddickerson's Avatar
ddickerson ddickerson is offline
Default 129 loader backhoe project
I have a 129 that I'm restoring. I also have a loader that I built three years ago that has been on my 105, and a backhoe that I built this past year. I plan to put both on a restored 129. Now, I want to re-power 129 with a Kohler 14 hp that I have out of a newer Wheel Horse with solid state charging system. The problem is that I need to find a way to adapt the drive shaft to engine because the flywheel is different than the 12 hp that was in the 129!! Now, do they make something or do I have to make one? If any one can help that would be great!!
100 with deck 3 point hitch plow and discs,105 with loader,125 with tiller,qa42a blower,and 48'' deck,1450 with 44'' deck, 129 under restoration for loader and backhoe project.
Old 03-07-2011, 06:02 AM
I have NO experience in this particular application but an educated guess would be that you will have to custom fabricate this adapter.
Old 03-07-2011, 11:19 AM
dieseldan123's Avatar
From what i hear the wheel horse engine is bigger in the lower end than the kohlers made for our cubs so making it fit into the frame rails a bolting into the holes is almost impossible. You will have to machine your own coupling to fit the drive shaft.
1967 IH Cub Cadet 123
1978 IH Cub Cadet 1650
19?? IH Cub Cadet 682
Old 03-07-2011, 03:22 PM
ddickerson's Avatar
ok guys thanks,i figured that i would have to make my own, but it was Worth a shot to see if there where something.
Old 03-14-2011, 04:12 PM
westofb's Avatar
westofb westofb is offline
I think I remember reading somewhere that you could use the flywheel and tins off a 301 on a 321, maybe even the pan could be used so it would bolt on correctly. I have no actual experience in this swap, just thinking I read this somewhere and tossing it out there for your consideration, if it would work should eliminate all your mounting issues.
Old 03-17-2011, 08:47 PM
jeffscub's Avatar
jeffscub jeffscub is offline
maybe some of them are but not all, i have a 12hp out of a wheel horse mounted in my 72' 108. bolted right up with no probs!!! jeff
'72 108 w/ 38" HIGH speed deck, '77 1200QL w/ homemade grader blade, '79 1450 44" grass tamer, '70 sears super 12 w/ 3pt , 19?? 100 w/ extra toys, 69' economy powerking 14 horse w/ FEL, 65' economy powerking w/ toys, 1982 allis chalmers 716
Jeff
Old 04-14-2011, 09:44 AM
riesedesperado6170's Avatar
riesedesperado6170 riesedesperado6170 is offline
Default answer i hope
I have to ask a question first, is the flywheel not have the dowel pin hole in it or is that the problem? If it is but there is 4 holes that treaded there, you can get drive adapter at www.midwestsupercub.net something pull you so there no limited on flywheels. I hope this helps but if it don't please if it don't give me more info and I will see what else i can come with. If it has a flat oil pan it may cause a driveshaft issues due to different height from base to center of flywheel but most blocks you can put cub style oil pan.
Jeremy
Old 04-18-2011, 08:37 PM
AMCJavelin74 AMCJavelin74 is offline
The 12hp Kohler is a pretty gutsy mill. I'd leave well enough alone... what's the issue with the WH, and is there anything wrong with the 12hp mill in your 129?
If there is something wrong with the Kohler in your CC, looking into a rebuild would be easiest, or finding a 14hp CC-spec Kohler.
If you're determined to go through with this, I wish you luck, and it probably won't be all that difficult, but you'll have to do some fab work to make it all work out.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 04-23-2011, 12:09 PM
ddickerson's Avatar
0422111750a.jpgheres some pics of the 129 project update!
Old 04-24-2011, 11:49 AM
Originally Posted by ddickerson View Post
Attachment 10742
Attachment 10743heres some pics of the 129 project update!
OH! Looking good! Got any more pics???
