Old 03-14-2011, 04:56 PM
red211's Avatar
red211 red211 is offline
Default Carb Bushing #?
Anyone know what the bushing size is at ace hardware for the throttle shafts? Got a kit at local dealer but they didn't have the bushings and I saw somewhere that ace had the right size for this. Am going to try to get them in a few minutes so----- any takers?
Old 03-14-2011, 05:49 PM
I think this is what you need:
7/16" o.d. x 1/4" i.d. x 1/8" thick
Old 03-15-2011, 09:55 AM
red211's Avatar
Thanks, I will check and see what I can find. I know someone had found them at a hardware store, just can't remember where I read it.
Old 03-15-2011, 02:11 PM
edw's Avatar
edw edw is offline
Default bushing
hillman 58087a is what I have wrote down
Ed Wells
Jeffersontown Ky
Old 03-15-2011, 06:53 PM
red211's Avatar
I just got back from Ace and the bushing that fits the shaft is too large for the carb bore. I can drill it out to fit, but really don't want to drill it if I don't have too. I would have to remeasure but the difference from shaft to bore is only something like .030. Not much more than a shim bushing. Drilling out the shaft bore would make room for a good size bushing. I read where there is a kit from Kohler that has a new shaft, bushing and screws, but the IH dealer here had a regular kit and didn't have any bushings, didn't act like he had heard of it. Had tune up stuff and a head gskt, walked right to them so I would think He would have at least known.
Old 03-15-2011, 07:10 PM
I recall having to drill my carb back when I did that upgrade. It isn't too bad, just go slow and steady. Use some Red Loctite when you put the bushing in. The drill was just small enough I had to use a light wooden hammer to seat the bushing.
Old 03-15-2011, 10:02 PM
red211's Avatar
Thanks, just wanted to be sure that is what you do. The hole will guide the bit, just hated to drill it and find out I have the wrong bushings. Did the carbs have bushings from the factory or just like they are and that is the problem. Guess 40 years is not too bad for a carb shaft.
Old 03-16-2011, 09:10 AM
GoatDriver's Avatar
GoatDriver GoatDriver is offline
Has anybody mic'd a Kohler bushing and then tried to find a match at McMaster-Carr?
Cub Cadet 126 - Cub Cadet 86 - Cub Cadet 108
The majority as to numbers, wealth,and political influence are often wrong. If in such cases a person would do right, he must not be governed by public opinion, however it may be expressed, but by the law of God. {see Proverbs 4:14}
Old 03-16-2011, 09:28 AM
Have you seen this yet?
http://cubfaq.com/throttle.html
Old 03-16-2011, 10:15 AM
I haven't been able to find a washer like that tho. Probably as always looking in the wrong places.. LOL
