Old 03-22-2011, 05:29 PM
edblast edblast is offline
Default 582 Special Question
I had to replace the clutch arm on my 582 Special and now all of a sudden when I take my foot off of the clutch/break pedal on any gear even neutral, it makes a loud rattling noise. The rattling stops though when i put even a little pressure on the pedal. I checked all bolts and they are tight. Any ideas on what could be causing the rattling?
Old 03-22-2011, 11:28 PM
lonnyb's Avatar
lonnyb lonnyb is offline
Just a thought, but is there a return spring that needs to be hooked up?
Old 03-22-2011, 11:55 PM
There is a return spring but it is already hooked up.
I checked diagrams and it seems like everything is where it is supposed to be but for some reason it still makes the rattling.
Old 03-23-2011, 03:51 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
I can't find a diagram for the 582s to see what the set up looks like,but is it possible that it is the throw out bearing rattling and stops when pressure is applied. If so try backing the clutch off a little bit so it doesn't touch.
Edit: I found a pic of a 482 clutch setup . It's not how i thought it was so what I said doesn't really apply .Sorry. Is it possibly a bearing starting to go out in one of the pulleys.
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 03-23-2011, 08:06 PM
Ok thank you. ill be sure to post if something was wrong with the pulley or not this weekend when Im able to bring it out. Its raining right now so I am not able to check it out at the moment.
