Old 03-29-2011, 09:19 PM
1811Cub 1811Cub is offline
YOU SIR ARE BAD A$$
Thank you very much !!!!!!!
It looks like I'll have to remove the fuel tank to get to this rascal
Old 03-29-2011, 09:36 PM
Just to clarify, that hardened steel pin is used only up to the 1x9 tractors. After that, 82 series and CCC tractors included, only spirol pins are used until the cyclops series when they changed the driveshaft.
If you have multiple tractors, the bags of 25 spirol pins from McMaster-Carr are cheaper than buying 2 or 3 individual ones from Cub Cadet or just about anywhere else.
Old 03-29-2011, 09:38 PM
Matt,
You happen to have the McCarr number for the spiral pins?
Old 03-29-2011, 09:42 PM
You might consider replacing those flex discs if you are into that far. They do weaken and wear out after several years. Just a thought.
Old 03-29-2011, 09:44 PM
http://www.mcmaster.com/#pins/=bnfq9k
(404) 629-6500.
Matt,
91598A486 should be the number
Old 03-29-2011, 09:47 PM
Thanks for the part number!
I will be ordering some soon.
Old 03-29-2011, 10:08 PM
95755A419 for the heavy-duty ones...they are about 40% stronger, and are the ones I use.
Old 03-29-2011, 10:48 PM
ajgross ajgross is offline
Inactive Member
The actual correct name for the pins is "Coiled Spring Pin". "Spirol" is actually a brand name.
AJ
Old 03-30-2011, 06:08 AM
Thanks Matt!
