Hello, just got the k161 in my 70 started and the great news is there is no smoke and runs strong !!! At low idle seems correct, but when i take it off of low, seems to rev Way too HIGH. What steps should I take to check / correct this? Thanks for your help.
1969 Cub Cadet 127 Cub Cadet HDS 2155 w/ bagger #2 IH cart 48" deck 42" Front Blade Brinly Sleeve Hitch and Brinly Plow IH wheel weights
Sounds like a Governor adjustment is needed. Click here for the K series Service Manual for the procedures.... Manual
I was looking at that . I never done anything like that before. Guess its time to learn
My buddy wanted to see a vid of it if i could get it running, so here it is.
http://jlefantephoto.smugmug.com/Mac...698_HtWCM-A-LB Its missing a few bolts here and there, but runs well.
Sweet video! Glad it's going so well.
Jason,here is what is needed to do with the gov.If the shaft keeps turning you have a problem with the gov cross shaft arm,and it is prolly broken off.
Cool vid, Jay! The 70 runs great!
What models steering column will fit my 70? Thanks Jason
all nf ones will fit but they will be 2" longer/taller.The 70/100 and the 71 use the shorter one I do believe. a wf one will work...Maybe one ofs youse udder guis mite knows ifs a 82 series will woik
Ok, i just checked all the linkage and the gov shaft and all seems well. I even pulled my 73 next to it and everything matches ! Now when i start it, low idle is perfect like i said before. If i push the throttle up very slightly, i can raise the idle up to high speed and its good, but if i go past the very slight mark, it starts to REV !! Does this sound like a govener problem, or maybe a carb problem? I am lost !!!! HELP
