Old 04-05-2011, 11:29 PM
Default Fabbed my exhaust flange and scored more parts
For my K321 build I will be building a custom muffler. I have also decided on a flange style exhaust into a short header feeding this muffler and all of it fitting in the stock location.
The flange. I will have to fab up some spacers and use studs on this.
And some newly scored parts. It came with another cast iron oilpan too!
OH yeah, and a #26 carb.
I am interested in a trading the sheetmetal, flywheel, and bearing plate for QL sheetmetal, flywheel and plate. I also have no use for the clutch or starter/gen brackets. Shoot me a pm.
Old 04-05-2011, 11:39 PM
william1041200's Avatar
Nice looking flange! The PITA of it is that kohler didn't space the bolt pattern far enough away to use it like that easily. The KT series has cast iron ' headers' that have thick bolt pads that span the internal bore bend- hope I defined that clearly. Basically, the bolts are 4 inches long roughly. LOL There are 2 different bends (one for each head ) and will fit 1.250 id tubing well.
Old 04-05-2011, 11:46 PM
I am gonna work my bend so I can incorporate spacers that fit on the stud over the flange so that I can turn the nuts to tighten them. I hope that makes since. Kinda like the exhaust studs are on a Detroit 60 Series diesel.
Old 04-06-2011, 01:56 AM
Nice score and nice work on the flange!
You'll have better results in making a posting in the wanted section of the site.
