Old 04-15-2011, 01:08 AM
Default help with 128
I need with couple of questions my 128 has what I think are lift arm holes /bushings high on the tail of the frame , are/were these used for a 3 pt lift arms or does the hitch pictured on the main forum fit this model ?
any advise on freeing up a lift lever lock button ( top) its been soaking in penatant trying to separate the arm from pivot today I have a oxy/act torch wish I had a exploded view
the lever on the other side is for ?
Old 04-15-2011, 09:32 AM
jeff k.'s Avatar
jeff k. jeff k. is offline
Check here.
http://www.cubcadet.com/webapp/wcs/s...0Cadet%20Parts
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 04-15-2011, 10:29 AM
red211's Avatar
red211 red211 is offline
PTO is the lever on the other side. A little PB got mine loosed up, but it was not stuck to bad. Good luck on the parts look up, if your like me you'll need it. A pic of the holes/bushings will help the experts here tell what you have.
