Old 04-15-2011, 09:04 PM
JaysNJcub127's Avatar
JaysNJcub127 JaysNJcub127 is offline
Default ummmm
1 ph = single phase, is not the same as 1 HP.=horsepower
if it is 1 hp, it is not a " big motor" but I guess it is all in what a person is comparing it to.
ok, running 1hp will use 5 to 7 amps........ just as a 5hp running motor will run at 25+.
I meant the motor was phisically big
1969 Cub Cadet 127
Cub Cadet HDS 2155 w/ bagger
#2 IH cart
48" deck
42" Front Blade
Brinly Sleeve Hitch and Brinly Plow
IH wheel weights
Old 04-15-2011, 09:15 PM
Great!
Size does matter!!
The bigger the motor is physically for a given H.P, the longer it will last.
That should make you a nice compressor yet not cost a lot to operate,
and not require heavy/special wiring.
