Old 04-18-2011, 11:44 PM
Ewilliams's Avatar
Ewilliams Ewilliams is offline
Default 782D 3pt hitch
Hello. I purchased a 782D this weekend. I believe it was made by CCC. All I have is IH built tractors so this is new to me, not to mention the Diesel. Anyway, is there a 3pt hitch that will work on this tractor besides the category 0? I looked on a parts listing and I don't see one like the ones that go on IH models.
Thanks,
Earl
Original, 1512, ih 982, ih 682
Old 04-19-2011, 06:08 AM
Earl:
YUP, the 782D is a CCC product.
Old 04-19-2011, 09:34 AM
inspectorudy's Avatar
Default 3 Pt hitch
I just went through the same quest myself. I found out that to use a WIDE FRAME three pt. hitch on my 1811, a CCC tractor, I had to get one of the shown bottom brackets made for an aluminum rear end and two frankenstien bolts from Patton acres, one of our sponsors above. I am not sure that the 782 has the same frame holes that mine does but I think it does. It has two large holes that are way too big for the rod that goes through the casting on the hitch. The two bolts take care of this problem. The bottom bracket is designed to not put the stress on the three bolts in the rear tranny cover plate but to use two of the axel bolts as well. If you buy the bracket from Extreme MW get the one that has the extra ears on it. The one with the two extra inner ears are for utensils that might bend the one ear model. Here are a couple of pictures of the bolts on my tractor.
Old 04-19-2011, 09:48 AM
Mountain Heritage's Avatar
Ummmm....
What's the hold up here???
Mike
Ontario, Canada
Now everyone wants a Cub!
Beware of the Wife
Old 04-19-2011, 12:50 PM
ajgross ajgross is offline
Inactive Member
You can't install a sleeve hitch on a 782D. The gas tank is in the way. Cat 0 3pt is the only way you can go.
AJ
Old 04-19-2011, 03:40 PM
Iluvtruks0's Avatar
AJ
Ditto. Kinda stinks forking over $500 but then you have a pretty sweet hitch setup.
David in NC
Old 04-19-2011, 06:52 PM
aagitch's Avatar
aagitch aagitch is offline
I think you can get one in the low $400 range from xtrememotorworks
Adrian
2072 (789513)
Old 04-20-2011, 07:35 AM
Tractor2nv's Avatar
Tractor2nv Tractor2nv is offline
AJ
FACT! It is the only way to go to have a rear lift...782D built in 1984 and replaced with the 882. Get ready to "lock-tite",wire lace,double nut,lock nut everything and sheet metal welding. Good "stiff" steering to build them arms. Keep a eye on the PTO,have been known to come loose and destroy the radiator. Starter too slow to crank? Gear reduction starter is the way to go and the little D600 Kubota power plant does not like cool weather either. Good luck and hopefully enjoy!
Fool me once shame on you,fool me twice...shame on me!
Old 04-20-2011, 05:42 PM
TheSaturnV's Avatar
Explain further please.
How do I "keep an eye" on it? Any specific nuts or bolts to check?
Do you mean hard to start? Mine runs fine in the cold.
Old 04-21-2011, 04:43 PM
Ewilliams's Avatar
Default Thank you
Thanks for all the help. I am kind of disappointed and can't afford the $500 now, because I just spend $2100 for the tractor. Maybe in a few months. Thanks for the advice on what to watch for on these also. I love the sound of the diesel, and the smell. I fire it up each morning before I go to work. Pretty soon I'll be able to get out and work it. Thanks again.
Earl
