Old 04-20-2011, 12:52 PM
Default Questions on a 128
I wanted to know what the bushings in the back of the frame are for in the pic either lift arms or for a wider style pivot ? I want to drag a mower behind my cub instead of a belly one for one reason to be able to raise it high to mow tall grass
and in the second picture ,on the trans cover it shows a slot for a creeper gear lever was this the case on non hydro tractors ? I do not see a arm or shaft on the trans
the 3rd picture is my other Cub (tiger) I hope I don't cut grass with it .
also lost spark looks like the motor coming out when it first started it threw out dirt daubber nests for a minute
Old 04-20-2011, 01:20 PM
The bushings are for the cross shaft that holds the upper part of the sleeve hitch...
The creeper slot was used on gear tractors to give the owner the option of installing a creeper later...Sometimes the covers get used on hydros as well, but a hydro by definition already has a creeper.
For loss of spark, check that your PTO is turned off when you are trying to start....then go thru the usual suspects, points, condenser, coil, wiring etc.
Nice plane.. how old is it?
Old 04-20-2011, 10:18 PM
Default 128
thanks for clearing up those questions im sure it is the points /condenser they have to be 20 years old but ill check the pto
Im building the T Cub from plans hope to finnish this year
theres one on U tube tigercub around a patch
Old 04-20-2011, 10:52 PM
Are you going to diy or off the shelf design?
Old 04-21-2011, 03:28 PM
Hey Duke I was first going to try to use the 4ft 128 belly mower and mount 10in castered tires on the back I need to find a hitch and c rod first Don
