Old 04-24-2011, 12:32 PM
hydrocub hydrocub is offline
Default wide frame spring assist
Trying to install a IH wide frame spring assist on a 129 but the spring
is rubbing against the trans . Anyone with a pic or diagram to ensure
I'm putting this on correctly . I have been known to dummy up once in awhile .
Old 04-24-2011, 03:09 PM
AMCJavelin74 AMCJavelin74 is offline
here's a pic from a different thread on here... NOT my tractor or pic. Just a fyi.
CC 128 (Sept. 74)... and other vintage non-CC LT/GTs.
Old 04-24-2011, 04:10 PM
Thanks ..saw that , but it doesn't show the rock shaft bolt up
Old 04-24-2011, 05:26 PM
Southtowns27's Avatar
Got a pic of how you have it installed?
Old 04-24-2011, 08:39 PM
I will get a pic tomorrow, but once you put it in there you will see there is only one way to bolt it up. Really no guessing to it at all.
Old 04-25-2011, 10:30 AM
That's what I thought DX3 ....I don't like the way it is rubbing against the hydro case
Old 04-25-2011, 11:35 AM
This might help
I have a hi res copy if you need it.
Old 04-25-2011, 12:09 PM
This might help
That is much better than my picture can show.
Old 04-25-2011, 01:48 PM
Thanks Lew ...at work now , but pretty sure that's how I had it ...
I'll check here out whenI get home
Old 04-25-2011, 04:38 PM
inspectorudy's Avatar
Default Are the springs for hydro models?
I was reading the PDF and noticed that it referred to the lift handle. Obviously they are talking about the manual lift handle. Does a spring assist do any good on a hydro lift model?
1811 Hydro
