Old 05-03-2011, 12:47 PM
shelbert shelbert is offline
Default Cub 100 pto problem
I have a question a about the pto on my model 100 cub cadet. When I got the tractor it had a Wide Frame pto on it instead of the narrow frame one.
Is there a physical size difference in the 2 or any reason why the wide frame will not work. The reason I ask is I am having a heck of a time getting the thing to work correctly. It keeps chewing up buttons when trying to turn off the deck. I have determined the button is hitting the three triangle tabs that are held down by the bolts and ripping it up.
If its not he pto type I cannot for the life of me figure out what is going on. As it is now I can engage the blades at will with it running but when its time to turn off the pto I have to turn the engine off and disengage the pto. If I do this it works perfectly.
The button as of now is new, replaced the button on the pto as well. Adjusted as per the little tool. Any ideas would be great.
Thanks in advance
